Home » Audio » Speaker » ?Horn Questions?
Re: CD horns [message #19095 is a reply to message #19094] Sat, 10 February 2007 21:51 Go to previous message
Cuppa Joe is currently offline  Cuppa Joe
Then, the dual-angle "conical" flare in those midbass horns is just a crude approximation of a curved flare. Oh, pooh! I was hoping that this configuration could solve my depth problem for a single horn and still act conically.
Actually, I simulated my horn (as is) in HornResp about a month ago. I modeled the Delta 10A, since you already showed that it worked well in a front-loaded horn, plus it was an inexpensive choice at Parts Express. The throat, being a slot, wouldn't model just using the total area, so I pretended that it was a square of the smallest dimension (the width). The horn was modeled in 4Pi space as the worst-case scenario for a live SR subsystem. One box was a little disappointing, but 4 boxes stacked as a line array --usually the minimum box requirement for most pro audio line arrays-- flattened right out and rolled off close to the lower cutoff target. The upper cutoff was a little higher than in your Midhorn (which I used as a reference point, thank-you) though it was inconclusive whether the 2kHz goal was met.
Previous Topic: Array Enclosure Plans ie Northcreek Designs
Next Topic: ?Horn Questions?
Current Time: Wed Oct 28 09:46:44 CDT 2026
