Home » Audio » Speaker » ?Horn Questions?
Pattern control and mouth size [message #19082 is a reply to message #19081] Thu, 08 February 2007 09:16 Go to previous messageGo to previous message
Mouth size sets the lower limits of pattern control. At frequencies where the horn is large compared to wavelength, the horn walls act as boundaries and set the pattern. But when the wavelength is no longer small compared to mouth size, it begins to act as a diffraction slot. The wall angle is no longer important, instead, the wave launch is that of single slit diffraction.
Assuming a constant flare angle, the frequency where pattern control is no longer set by wall angle is determined by mouth size. If the mouth is axisymmetric, then the frequency where this happens is the same in the vertical and horizontal plane. If, on the other hand, the horn is wider than tall, then the horn will act as a diffraction slot that widens the flare in the vertical plane before it begins to do this in the horizontal plane.
Previous Topic: ?Horn Questions?
Next Topic: North Creek 13W Driver
Current Time: Wed Oct 28 08:53:13 CDT 2026
