Home » Audio » Speaker » Listening distance from speaker
Re: It depends... [message #19052 is a reply to message #19047] Wed, 31 January 2007 07:12 Go to previous messageGo to previous message
3. The steeper the crossover slope, the closer you can sit.
HI Duke,
Intuitively, I would have thought the less the lsope the closer you can sit, since the sound will be more "blended between the 2 drivers, whereas, if the slope is steeper, the sound is "more obviosuly split" between the 2 drivers. So, given constant spacing in both cases, if case 1 has a woofer & mid crossed at 500 Hz (say) with a 12 db slope, the sound may blend in better than case 2, where the slope may be 24 db. I say thin in the context of eh Altec VOTT setup...do you think making the slope steeper between the dome & the horn makes the sound more coherent or less, at smaller listening distances?
BTW, I use a 24 db slope in my system, and cross it at 1500hz, but I kow the traditional passive Altec Xover uses 12 db & crossed at 800 Hz.
-akhilesh
Previous Topic: Word document for cutting flange of Neo Tweeters
Next Topic: Fostex FE126e
Current Time: Sat Oct 31 07:11:31 CDT 2026
