Home » Audio » Speaker » Please recommend a smooth 18" x 8" HF horn & driver...
Thanks, I appreciate it. (nt) [message #19029 is a reply to message #19027] Sat, 23 December 2006 12:14 Go to previous messageGo to next message
LineArrayNut is currently offline  LineArrayNut
nt
Re: Please recommend a smooth 18" x 8" HF horn & driver... [message #19031 is a reply to message #19018] Tue, 26 December 2006 10:13 Go to previous messageGo to next message
No luck on the 811b horns, I checked and I have only 1 but it's damaged. You might keep an eye on ebay they pop up there ocassionally.
Bill W.
THX anyway! (nt) [message #19032 is a reply to message #19031] Wed, 27 December 2006 00:33 Go to previous messageGo to next message
Still looking for horns? [message #19040 is a reply to message #19018] Wed, 10 January 2007 08:17 Go to previous messageGo to next message
I know someone who might have a pair of Altec 811b horns.
I looked up your IP. You're in the Cleveland area, right?......C
I went ahead and bought the whole VOTT...(PIC) [message #19041 is a reply to message #19040] Thu, 11 January 2007 09:15 Go to previous messageGo to next message
I'm in Dayton, TN. I think I mighta paid too much, what do y'all think? $1475 shipped from Miami, FL for the pair.
2 Altec 828 Cabinets
2 Altec 15 inch 416 8A Low Frequency Drivers
2 Altec 807 8A High Frequency Drivers
2 Altec 811 Sectoral Horns
2 Altec N 1285 8A Passive Crossovers
Re: Please recommend a smooth 18" x 8" HF horn & driver... [message #19042 is a reply to message #19018] Sun, 14 January 2007 20:48 Go to previous messageGo to next message
Since I first suggested the Altec 811b horns, I have purchased two pair on ebay without difficulty. One pair was a VERY new looking Heathkit 811b pair.
I don't see any difficulty in buying these.
Re: I went ahead and bought the whole VOTT...(PIC) [message #19043 is a reply to message #19041] Tue, 23 January 2007 14:19 Go to previous messageGo to next message
DMoore is currently offline  DMoore
Less than 700 each? Not too bad providing everything works. A little paint, and you're jammin.
DM
They sound OK, big azz image throw, but polarity ?'s (please help) [message #19049 is a reply to message #19043] Tue, 30 January 2007 07:13 Go to previous messageGo to next message
The shipper screwed up and shipped them on a small pallet and splintered the bottoms, oh well. They work good, no low bass or upper highs, but are ok. Question is, the horns have no obvious polarity markings. The terminals are on top. Looking from the back at the driver, which side is positive and negative? thanks for the replies!
Look for a notch in response [message #19050 is a reply to message #19049] Tue, 30 January 2007 09:23 Go to previous messageGo to next message
Do you have access to any measurement equipment where you can look for a notch in response from out-of-phase signals? If not, maybe download Speaker Workshop. If the tweeter is miswired, you'll see a notch in response somewhere within an octave of the crossover frequency.
Terminals are marked "1" and "2" [message #19051 is a reply to message #19050] Tue, 30 January 2007 16:47 Go to previous messageGo to previous message
spkrman57
Altec used this to determine polarity.
I believe(from memory only) that termnal "2" is positive and "1" is negative for a positive waveform exiting the horn mouth.
Regards, Ron
Previous Topic: Fostex FE126e
Next Topic: Newform R30 Scanspeak 18W/8545 array project
Current Time: Mon Oct 19 17:31:45 CDT 2026
