Home » Audio » General » What to buy - $150 amp (stereo) and $250 speakers
What to buy - $150 amp (stereo) and $250 speakers [message #1900] Sun, 19 June 2005 13:38 Go to next message
s7on3d is currently offline  s7on3d
Hi Guys,
I'm planning to buy a small sound system to connect in my small room. I'm going for a stereo system since I plan on using it only for music. I listen to lots of classical, Jazz (both calssic and modern), and quite a bit of calssic rock.
My budget is quite small - around $150 for an amp and $250 for speakers. I want to know what you guys think would be the best match for my current situation.
Thanks in advance,
Ilan
Re: What to buy - $150 amp (stereo) and $250 speakers [message #1901 is a reply to message #1900] Sun, 19 June 2005 17:09 Go to previous messageGo to next message
I would sugges the cheap tripath chip amps (liek a sonic impact or Teac) and Klipsch bookshelf speakers if you are going new. If you are going used, that's another matter. Let us know.
-akhilesh
Another take. [message #1902 is a reply to message #1900] Sun, 19 June 2005 20:46 Go to previous messageGo to next message
Poindexter is currently offline  Poindexter
Hi, Ilan,
The most amazing sound/$ I have heard has been from compact systems from the better Japanese manufacturers; Denon, Luxman (not, oddly enough, Nakamichi).
The integration of the response of the input components, power amp, speakers, gives a wholeness to the sound that can humble high end separates at four times the cost.
Check over on eBay for these things; I bet you can meet your budget and please your ears.
Aloha,
Poinz
Re: What to buy - $150 amp (stereo) and $250 speakers [message #1903 is a reply to message #1901] Sun, 19 June 2005 21:36 Go to previous messageGo to next message
I was going to suggest a Sonic Impact amp and a pair of Axiom M3ti speakers (assuming you don't go diy on the speakers.
For a lot less money [message #1904 is a reply to message #1900] Mon, 20 June 2005 06:12 Go to previous messageGo to next message
you can buy a pair of small active monitors.
Re: For a lot less money [message #1905 is a reply to message #1904] Mon, 20 June 2005 08:50 Go to previous messageGo to next message
What a great recommendation, Charlie(?).
That would be a good way to go!
-akhilesh
Those axiom speakers have gotten great reviews [message #1906 is a reply to message #1903] Mon, 20 June 2005 08:54 Go to previous messageGo to next message
Hey, thanks for mentioning those Axiom speakers. I did a quick read on them, and they sound like a DArn good value for the money! Also, the 93 db eff will allow the use of the sonic impact amp!
-akhilesh
Re: What to buy - $150 amp (stereo) and $250 speakers [message #1908 is a reply to message #1901] Mon, 20 June 2005 14:07 Go to previous messageGo to next message
I've looked around at some of those options and I'd love to hear some more. I want to buy everything new. I want an amp and speaker system because depending on my budget later in life, I'd like to expand and upgrage the system piece by piece (firstly by adding a sub as soon as I have the cash... which may be quite a while). I have absolute no plans of building anything myself, as I dont have enough free time. You guys have some more options for good amps?
Re: What to buy - $150 amp (stereo) and $250 speakers [message #1909 is a reply to message #1908] Mon, 20 June 2005 14:40 Go to previous messageGo to next message
I'd go with the axiom speakers, and a tripath based amp, like the TEAC or the sonic impact.
-akhilesh
They're even a better deal if you buy from their outlet [message #1910 is a reply to message #1906] Mon, 20 June 2005 14:49 Go to previous messageGo to previous message
Previous Topic: A/B Testing/Weber Fachner Law
Next Topic: CORAL BX-1500 Speakers
Current Time: Thu Nov 05 08:32:09 CST 2026
