Home » Audio » Speaker » Speakerlab K Horn
Re: Speakerlab K Horn [message #19033 is a reply to message #19016] Thu, 28 December 2006 18:13 Go to previous messageGo to previous message
DMoore is currently offline  DMoore
I have the original 1979 Speakerlab "K" plans, and that is definitely NOT a 100Hz flare rate at the throat. I also haven't ever seen this article that you reference.
The plans show the same 50Hz flare rate used by the original Klipschorn. Also the remaining "K" flares are 32 and 38Hz respectively with the same overall horn pathway length (approx. 64 linear inches). Both horns employ a 78 sq. in. throat area cross-section. A virtual Khorn knowckoff with a couple of improvements, funny since they were originally included in the 1946 Klipsch plans (a 12" driver size) but were subsequently dropped by Klipsch production some time later. These include back chamber "stuffing" and back chamber/channel axially aligned bracing to reduce vibration.
Most likely, the THROAT CAVITY OPENING of the Speakerlab "K" is the so-called "wrong" part, evidently copied directly from a post-1962 Klipschorn, being that it is 3" wide versus the 6" wide typically used for a non-K33 driver, such as the W1508S 8 Ohm driver used by Speakerlab. This is where the SL "K" MAY have been improved BUT I heard a pair of "K"s at the time, and in no way do I think that they suffered in the least from using the smaller slot size. I've NEVER heard a Klipschorn that beat them on the bass-end to this day.
DM
Previous Topic: so I built these lines with a single tweeter
Next Topic: Pick the right mid/woofer
Current Time: Wed Oct 21 18:46:24 CDT 2026
