Home » Audio » Speaker » Your Experiences With Constand Directivety Horns
Re: Your Experiences With Constant Directivity Horns [message #19004 is a reply to message #19002] Thu, 09 November 2006 18:58 Go to previous messageGo to next message
PointSource is currently offline  PointSource
Then, what would be your product recommendations for decent non-diffractive CD horns, whether cheap or expensive?
Re: Your Experiences With Constant Directivity Horns [message #19005 is a reply to message #19004] Thu, 09 November 2006 20:48 Go to previous messageGo to next message
There are lots of horns that are good, it really depends on what you need and/or expect, such as frequency band, angular coverage, symmetrical or asymetrical, and quality of pattern control. For example, if you just need a tweeter, then the horn doesn't have to be all that large for true CD. The lower in frequency you need pattern control, the larger the horn needs to be. There are lots of things to consider. Look at horns from Eminence, DDS, etc.
Re: Your Experiences With Constant Directivity Horns [message #19006 is a reply to message #19003] Thu, 09 November 2006 20:56 Go to previous messageGo to next message
Thanks, guys. You're making me blush.
Duke, you're too understated. Fred Thompson and I were just talking about that last night at dinner. You've made quite a few nice contributions in the field yourself.
Re: Your Experiences With Constand Directivety Horns [message #19007 is a reply to message #18997] Sun, 12 November 2006 10:27 Go to previous messageGo to next message
Great link to the paper, Duke.
Thanks
-akhilesh
Re: Your Experiences With Constand Directivety Horns [message #19030 is a reply to message #18994] Mon, 25 December 2006 19:11 Go to previous message
Todd W. White is currently offline  Todd W. White
ALL constant-directivity (actually a misnomer, but I digress) horns have, as do all things in general, some flaws that must be understood and compensated for (or, at least, tolerated) in order to get the most out of them.
1. The most noticeable problem with them is that they suffer from what Mark Ureda describes as an problem with "Apparent Apex." Simply stated, this means that ALL constant-directivity have at least TWO locations within the driver/horn assembly from whence the sound appears to originate. In the vertical plane, the apparent origin to the listener's ear of where the sound starts is at the comrpession driver. HOWEVER, in the horizontal plane, it appears to originate at the point where the diffraction slot (or curve, for you EV and JBL fans) opens into the bell flare.
The ultimate result is that the sound appears to originate somewhere between the two points.
But it doesn't stop there.
That's only at ONE frequency - the horizontal apex shifts with frequency, resulting in a really interesting, and sometimes difficult to listen to, phenomena.
With the WE/Altec multicellular horns, this problem did not exist - the origin (apex) of the sound source on a multicellular horn start AT EXACTLY THE SAME PLACE: where the horn bolts to the throat. That's why they were hand-filed to almost razor-sharp: to eliminate any reflections back into the throat area, AND to make SURE that the sound emanated from the same spot in the vertical AND the horizontal planes.
As my old friend Don Davis likes to say, "Those guys in the Bell Labs really knew their math - they understood what was going on, acoustically, and made sure they found a way to do it right!"
To solve this problem in multiple horn arrays, Mark Ureda came up with an interesting compromise which actually worked quite well, although the arrays ended up looking pretty strange at times - nothing at all as beautiful as the symmetry we used to see in the big 210/211 clusters with multicellular horns.
Our friend Ted Uzzle teamed up with Mark to write an Altec Technical Letter about this called, "TL-262 = Coverage Of Multiple MANTARAY® Horns." This is a paper whose concepts are still not understood by most modern acoustical consultants, sound system designers, and sound contractors, and is a MUST READ for anyone interested in how to cover large areas with multiple constant-directivity horns while minimizing phase interference, and maintaining apparent apex.
You can find it here:
http://alteclansingunofficial.nlenet.net/publications/techletters/TL_262.pdf
2. All that said, these horns DO work well. Quite well, in fact. BUT it must be remembered that, for all their detractors, multicellular horns do not exhibit the beaming problems nearly as bad as Thomlinson Holman and his ilk liked to say they did. John K. Hilliard said that he had to slow the turntable down in the anechoic chamber to it's lowest setting and speed the recording pen up to full in order to even be able to MEASURE the lobing problems mentioned in Leo Baranek's book "Acoustics", which is where those who hate multicell's (and Altec) got a lot of their fuel.
But hey - in real life, you can't hear it, unless you're listening to pink noise, and who listens to THAT for any length of time at all unless they have to?
3. The only really CD horns from the "Big 3" who brought them to prominence are the MANTARAY ones designed and built by Altec. They have precise coverage patterns, unlike the ones from EV & JBL, which were far less accurate - not really "constant". While you could walk in or out of the MANTARAY coverage pattern, with the others, you kind of faded into or out of theirs....
All told, CD horns are, like everything else, a compromise. If they do what you want and sound good, use them. If not, keep searching, but don't bypass some of the better older designs - you might be surprised at how well they work.
Previous Topic: Zu tone or Druid or which Omega to match 300B?
Next Topic: merry christmas line array people and others
Current Time: Wed Aug 14 20:03:23 CDT 2024
