Home » Audio » Speaker » Bandpass for JBL 2240H
Re: Bassreflex suggestion [message #18821 is a reply to message #18820] Mon, 14 August 2006 21:44 Go to previous message
GM is currently offline  GM
Greets!
Bummer, I was hoping you'd try a big folded TL that sims 100 dB/W/m half space from 30-70 Hz. You could use it as a platform to mount your mains/whatever. Two would get a bit unwieldy though unless stacked on top of each other against the wall.
In theory, you'll get ~112.78 dB/600 W/m/20 Hz/half space peaks with one, so summing two = ~115.79 dB in 'stereo', but ignoring room gain it will be less due to thermal power compression.
GM
Previous Topic: Needle Array Plans?
Next Topic: Planar speakers
Current Time: Sat Oct 31 03:51:59 CDT 2026
