Home » Audio » Speaker » Need help with room placement
Re: Need help with room placement [message #18774 is a reply to message #18770] Wed, 07 June 2006 16:05 Go to previous messageGo to next message
Wayne, help me, DI? What you wrote sounds interesting, can you say it again in English??
Put your left toe-in....... [message #18775 is a reply to message #18774] Wed, 07 June 2006 16:27 Go to previous messageGo to next message
Have you tried toe-in? Focus the speakers to cross several feet (5' or so) in front of your listening position and then move several degrees to a toe-out position. You should find a position where the depth/imaging/soundstage comes together. Also, are your speakers along a long or short wall? Try the other wall just to see if there is a difference.
I don't have the Cardas site at hand, but look on their site for some good info on speaker placement, if you have not already.....Best regards, Colin
Re: Put your left toe-in....... [message #18776 is a reply to message #18775] Wed, 07 June 2006 17:59 Go to previous messageGo to next message
Thanks, Colin! I have the speakers positioned about where the Cardas site recommends - about 55" from each side, and 80" from the back. The funny thing is that the JBL horns image wonderfully, but not the 811's. So I guess the problem is solved except I like the sound of the 806 drivers better. So I guess I need to find a 2 bolt to 3 bolt adapter.
Re: Put your left toe-in....... [message #18777 is a reply to message #18776] Wed, 07 June 2006 19:34 Go to previous messageGo to next message
I bet Ron's got a set......Colin
Re: Need help with room placement [message #18778 is a reply to message #18774] Wed, 07 June 2006 21:16 Go to previous messageGo to next message
DI is directivity index. Collapsing DI is what horns with exponential and tractrix and shapes like that have. Basically what it means is dispersion angle grows narrower as frequency goes up.
Re: Need help with room placement [message #18780 is a reply to message #18771] Thu, 08 June 2006 09:28 Go to previous messageGo to next message
Watch out for nulls though. When a boundary is 1/4λ away, a null forms at that frequency. Two feet is 1/4λ of 140Hz, three feet is 1/4λ of 100Hz, and so on.
Re: Put your left toe-in....... [message #18781 is a reply to message #18775] Thu, 08 June 2006 17:14 Go to previous message
This is exactly what I have found in my similar sized room. A7 s are in the corners, toed in to a point in front of the listening position. This gave a big Image with depth.
Russellc
Previous Topic: Tweeter or Super-tweeter
Next Topic: Xover and line array
Current Time: Mon Nov 16 06:52:36 CST 2026
