Home » Audio » Speaker » Mounting an 811 horn
Re: Mounting an 811 horn [message #18761 is a reply to message #18758] Mon, 05 June 2006 22:14 Go to previous message
If baffle mounting, it's best if you can make the mouth flush. A smooth transition is what you want with no abrupt changes. Also, baffle mounting makes the horn radiate into halfspace (as opposed to full-space) if the baffle is large enough. The 811 is large enough that it really doesn't need it if the crossover point is above 800Hz. But you can't ever be too smooth.
Previous Topic: Void Filling Foam?
Next Topic: Maxxhorn
Current Time: Sun Nov 08 12:36:52 CST 2026
