Home » Audio » Speaker » How do I measure the Le of a speaker?
How do I measure the Le of a speaker? [message #18695] Wed, 05 April 2006 09:06 Go to next message
Tre' is currently offline  Tre'
"Le
This is the voice coil inductance measured in millihenries (mH). The industry standard is to measure inductance at 1,000 Hz. As frequencies get higher there will be a rise in impedance above Re. This is because the voice coil is acting as an inductor. Consequently, the impedance of a speaker is not a fixed resistance, but can be represented as a curve that changes as the input frequency changes. Maximum impedance (Zmax) occurs at Fs."
I'm trying to implement a Zobel on a Trusonic FR80. I would like to find the TS's for this speaker.
Thanks...Tre'
Re: How do I measure the Le of a speaker? [message #18696 is a reply to message #18695] Wed, 05 April 2006 10:28 Go to previous messageGo to next message
Measure the impedance of the speaker to find Le. It will be a complex impedance, having both reactance and resistance. You can use a Wheatstone bridge (inside a dedicated tester) or one of the measurement systems like Speaker Workshop to find impedance of your speaker.
LCR meter [message #18697 is a reply to message #18696] Wed, 05 April 2006 18:35 Go to previous messageGo to next message
spkrman57
Like from Parts Express.
I use mine often for testing tolerence of caps and coils!
Ron
Re: How do I measure the Le of a speaker? [message #18702 is a reply to message #18695] Thu, 06 April 2006 17:02 Go to previous messageGo to next message
Martin is currently offline  Martin
Unfortunately, the effective Le and Re of the speaker's voice coil are going to change with increasing frequency. Fortunately, the Zobel circuits are not that sensitive so getting a Le and Re result at 1 kHz is good enough for sizing the Zobel. This is why there is typically a 25% factor in the rule of thumb equations for calculating the Zobel's capacitance and resistance.
Martin
Re: How do I measure the Le of a speaker? [message #18703 is a reply to message #18702] Thu, 06 April 2006 22:44 Go to previous messageGo to next message
Thanks, but how do I measure inductance at 1K hz? Can I make a inductance bridge like a impedance bridge?
I have an inductance meter but I don't know what freq. it uses.
Tre'
Re: How do I measure the Le of a speaker? [message #18704 is a reply to message #18703] Thu, 06 April 2006 23:07 Go to previous message
I found it. Le=(sqrt(3)*Re)/(2*pi*fx)
I have to find Re and fx first, but the article shows how to do that.
Thanks...Tre'
Previous Topic: Impedance correction at a compression driver's Fs - How to calculate - Wayne P?
Next Topic: AudioRoundTable Archive
Current Time: Fri Jun 28 21:36:46 CDT 2024
