Home » Audio » Speaker » Is calculations of L-pads based on "nominal impedance" or Re?
Re: Is calculations of L-pads based on "nominal impedance" or Re? [message #18673 is a reply to message #18669] Wed, 29 March 2006 10:05 Go to previous messageGo to previous message
Peter K is currently offline  Peter K
Hi Wayne,
Thanks a lot for your reply!
Smoothing out the impedance curve is actually the main reason why I want to use L-pads (I will use an active crossover between the bass and the BMS, so level matching is not really necesary, but I may have to level between the BMS mid and high section [the BMS is a "coax"]).
Below I have attached a link to the BMS driver. In the second graph of the driver's response the impedance curve is shown (I know the horn is different than the one I will be using, so the response will not be completely identical on my horn).
Unfortunately, I haven't got measuring equipment myself, so I can not provide an impedance plot of the driver on my horn. But given the info provided (nominal impedance: 16 Ohm, Re= 8.9 Ohm, and the graph in the link), may I ask:
Which R-value would you base the L-pad calculation on?
I would really appreciate your expert opinion on this - thanks!
Regards
Peter
Previous Topic: Experience with BMS 4592 ND (16 Ohm)? A few questions - Bill M.?
Next Topic: Goldenvoice speakers
Current Time: Tue Nov 03 09:09:16 CST 2026
