Home » Audio » Speaker » Is calculations of L-pads based on "nominal impedance" or Re?
Re: Is calculations of L-pads based on "nominal impedance" or Re? [message #18669 is a reply to message #18666] Wed, 29 March 2006 08:43 Go to previous messageGo to previous message
If you want to do it right, you have to consider actual impedance. Your padding values will not just set attenuation but will also affect the Q of the circuit, which will adjust an amount of peaking or damping. The impedance curve of horns has ripples near lower cutoff, and these can be quite severe. When properly setup, the attenuation resistors will smooth these ripples and make overall response better.
Previous Topic: Experience with BMS 4592 ND (16 Ohm)? A few questions - Bill M.?
Next Topic: Goldenvoice speakers
Current Time: Tue Nov 03 10:23:00 CST 2026
