Home » Audio » Speaker » Sim help?
Sim help? [message #18640] Sat, 04 March 2006 19:09 Go to next message
hey-Hey!!!,
Is there anybody who'd render a bit of modeling assistance for a front horn and driver?
Driver is EV's DL10X. The horn will be a conical, 5' axial, 40-degree included angle, 6" throat. Back volume is TBD and will be adjustable in place.
For complete driver specs...
http://www.telex.com/Electrovoice3/files.nsf/Pages/DL10X/$file/dl10x-eds.pdf
Thanks in advance.
cheers,
Douglas
Hornresp [message #18642 is a reply to message #18640] Mon, 06 March 2006 15:03 Go to previous messageGo to next message
Do you have Hornresp? If not, grab a copy. Entering the electro-mechanical parameters is a snap, just click on the fields in the lower area of the screen and type them in. You can even double click these fields and the program will prompt you for T/S specs, which it will then convert to force/mass/compliance values. The rest of the data entry is equally simple, just enter length and area and front and rear chamber volume. If you get confused, I'll send you one of my data files as a starting reference. You can always write a post here if you get stuck.
Re: Hornresp [message #18643 is a reply to message #18642] Mon, 06 March 2006 17:10 Go to previous messageGo to next message
GM is currently offline  GM
Greets!
FYI, scroll down to the basshorn design/Hornresp tutorial........
GM
Re: Hornresp [message #18644 is a reply to message #18643] Mon, 06 March 2006 22:07 Go to previous message
Great link, thanks!
Previous Topic: What is the optimal frequency range for a single driver to reproduce?
Next Topic: Raw Acoustics Omega's
Current Time: Tue Oct 20 17:24:25 CDT 2026
