Home » Audio » Speaker » And now for something completely different ......
Re: 50Hz - 200Hz [message #18523 is a reply to message #18518] Mon, 30 January 2006 17:47 Go to previous messageGo to previous message
Martin is currently offline  Martin
Wayne,
"I haven't listened to the Dayton woofers, they may really sound good. Maybe their distortion levels are very low."
What type of distortion are you describing? If it is displacement generated then I would counter by saying that I have two 97 dB/w/m 15 inch woofers wired in parallel and even at loud volumes the motions are so small they are not visible. Where would distortion be generated?
I believe that these Dayton drivers are made by Eminence, but I might be wrong, which indicates quality to me. When I compared the Dayton's T/S parameters, and the physical description, I was convinced they were identical at that level to the JBL 2226. You have worked with many drivers so I am looking for an opinion on where I can improve, I have only worked with these Daytons. What would I be missing that might make them behave differently then the JBL drivers below 200 Hz?
Martin
Previous Topic: Vintage speakers vs. modern
Next Topic: magnets
Current Time: Fri Nov 27 06:04:00 CST 2026
