Home » Audio » Speaker » Dipoles and directivity
Dipoles and directivity [message #18501] Sat, 28 January 2006 11:45 Go to next message
Rapid is currently offline  Rapid
Hello!
Is it possible to get more directivity in the bass region, 20-80Hz, with dipole subwoofers? My first idea was a ring of multiple speakers but I guess a 4m (13.1ft) in diameter ring would only have 6dB directivity at 344/4=86Hz?
Cheers,
Mattias
Re: Dipoles and directivity [message #18511 is a reply to message #18501] Mon, 30 January 2006 06:38 Go to previous messageGo to next message
Once one is below the Schroeder frequency, directivity is not really a very valid concept as the rooms modal pattern dominates the situation regardless of the source type. Although different source types do excite the modes differently, directivity is not really the issue.
Now from say 200-500 Hz a dipole directivity could be of use, but I've tried to make this work and can't seem to work it out effectivly.
For the neighbors then? [message #18512 is a reply to message #18511] Mon, 30 January 2006 09:48 Go to previous messageGo to next message
OK, but if I live in an appartment and would like to disturb the neighbors as little as possible. Would this help to reduce the bass they're hearing?
Cheers,
Mattias
Re: For the neighbors then? [message #18513 is a reply to message #18512] Mon, 30 January 2006 10:34 Go to previous messageGo to next message
Only to the extent that the dipoles produce much less bass.
Issolating bass is by far the most diffiuclt of all noise control problems. Complete structural issolation is usually required and this is completely out of the question unless you own the space.
If you don't own the space then the only solution is the volume conrol.
Re: For the neighbors then? [message #18521 is a reply to message #18513] Mon, 30 January 2006 13:07 Go to previous message
I was afraid that would be your answer As always, you give fast and good answers to questions. Thanks alot Earl!
Previous Topic: These are magnificent, Altec that is.....
Next Topic: Vintage speakers vs. modern
Current Time: Thu Nov 26 10:26:33 CST 2026
