Home » Audio » Speaker » Conical front horn
Conical front horn [message #18304] Sun, 27 November 2005 07:22 Go to next message
Hey-Hey!!!,
In and among other work I am *FINALLY* getting to build the wood conical horns for my RCA compression drivers.
37-degree included angle, 18" axial length, and a 1.375 throat to match the driver.
I am planning on 1/2" birch ply-wood for the construction. 8 petals, with a 22.5-degree chamfer( 'cause that is what is available from the router bit salesmen ).
Considering how well the experimental version sounds, these ought to be Sa-Mokin'... The experimentals were Fostex FE107's in 30-degree 6-petal 17" horns. They took a single afternoon to create with help from Home-Depot's saw man, and 5-minute Epoxy. 2" throat on those.
cheers,
Douglas
Re: Conical front horn [message #18305 is a reply to message #18304] Mon, 28 November 2005 08:19 Go to previous message
Where are the pictures? That's amazing you got someone at HD to actually help with custom cuts......Colin
Previous Topic: what are power extremes/ or nominal power to be....
Next Topic: Filling behind the horn of the A7/828 cabinet
Current Time: Fri Oct 16 15:22:05 CDT 2026
