Home » Audio » Speaker » Folded horns with curves, about 60 – 500 Hz
Re: Folded horns with curves, about 60 – 500 Hz [message #18291 is a reply to message #18288] Mon, 21 November 2005 09:38 Go to previous messageGo to previous message
I've built horns that do this, and I can tell you that there are several suitable designs. A straight horn will do it, and so will a folded horn if the bends are arranged so the higher frequencies propogate out. The thing is that there's a bit of a balancing act, in fact, several. The most obvious is wavelength related. The horn must be large enough that the diaphragm is loaded at low frequencies, but that means the dimensions will be several wavelengths at higher frequencies. So not only do you have issues of wavefront propogation and reflections but also standing wave modes and propogation time.
Previous Topic: Mounting Woofer
Next Topic: what are power extremes/ or nominal power to be....
Current Time: Wed Nov 18 11:35:45 CST 2026
