Home » Audio » Speaker » Anyone Familiar with the Onken Cabinet Alignment?
Re: Anyone Familiar with the Onken Cabinet Alignment? [message #18235 is a reply to message #18234] Fri, 04 November 2005 13:02 Go to previous messageGo to previous message
GM is currently offline  GM
Greets!
You're welcome! Correct, I used a 3.2 DF (2.5 ohms output impedance) to get the alignment, but ideally you would design around your amp's DF. ?? I mean this is what the measured specs I have calcs, and of course the big vents is what makes the Vb calc'd from the posted dims somewhat greater. Using published specs I get ~8.97 ft^3 net/~38 Hz Fb, so should still work fine in a slightly oversized/lower Fb cab.
GM
Previous Topic: Needed power to drive Jordan JX92S TL's
Next Topic: RE: mounting woofer
Current Time: Mon Nov 02 12:26:56 CST 2026
