Home » Audio » General » Visit to Spkrman57's house (pic)
Visit to Spkrman57's house (pic) [message #1821] Fri, 27 May 2005 22:18 Go to next message
Finally got around to posting a picture I took of Ron's "museum" or at least the garage wing. Had a great time as always. As you can see, I picked up the A7 cabs. They are now sitting in MY garage waiting to be finished. I just need to put a couple boards across the horn port and wire everything up. I'll get picts up when this is done......Colin
Porting the A7 [message #1825 is a reply to message #1821] Sat, 28 May 2005 12:07 Go to previous messageGo to next message
Hi Colin
A couple of years ago I built (and subsequently did everything I could think of to) a pair of 825 cabinets.
Realize that this cabinet pre-dated T/S, was essentially never revised with respect to sonic performance from the time of its introduction and was primarily intended to wring the most sound (not necessarily the most accurate bass reproduction) from low powered tube amps. It has very little bass ouput below 60 Hz in its stock form (using single frequency SPL meter measuremets).
Many experiments, but without the aid of RTA which I didn't have at the time,indicated that a port height of approximately 3" was optimal with the 515-G. You might do some searching on the Altec board in this regard as others expressed much the same opinion.
Re: Porting the A7 [message #1826 is a reply to message #1825] Sat, 28 May 2005 12:11 Go to previous messageGo to next message
I've been cruising the Altec boards trying to find all the mods needed to bring these cabs "up to date." You're dead-on with the 3" rec. This seems to be the most prefered port height, giving an area of around 100 inches square. Any other tech tips you have to offer are more than needed.....Colin
Re: Porting the A7 [message #1827 is a reply to message #1825] Sat, 28 May 2005 13:55 Go to previous messageGo to next message
He's using the 4168c though; have you investigated that driver in the A7 cabinet at all? I know some A7's came with 416's but the cabs with that woofer I have seen had 811 horns and 802's.
Read this, if you haven't yet. [message #1828 is a reply to message #1826] Sat, 28 May 2005 16:48 Go to previous messageGo to next message
Covers the waterfront.
Re: Read this, if you haven't yet. [message #1829 is a reply to message #1828] Sat, 28 May 2005 17:17 Go to previous messageGo to next message
Have you done anything with the 288 drivers? Any listening comparison with the small HF drivers, 806/802? The 515g; many seem to think the Ferrite version sounds better but I cannot get a sidexside in order to judge. Any thoughts?
Sorry, no [message #1831 is a reply to message #1829] Sun, 29 May 2005 07:01 Go to previous messageGo to next message
Never had the opportunity to play with the large format drivers - they're just so expensive.
But there may be some indication based on my new toys, the JBL 2435s. It seems as true as ever that a big driver loafing beats a smaller driver working every time.
Re: Sorry, no [message #1832 is a reply to message #1831] Sun, 29 May 2005 09:03 Go to previous messageGo to next message
Good way to approach it. One regret I have is not ever hearing the 288/515g/1505. Properly loaded and with the right cross-over.
Something to look forward to. There is a pair of A7's by me with 511/515's for $1k. If I only had the room.
2¢ more [message #1834 is a reply to message #1828] Sun, 29 May 2005 11:57 Go to previous messageGo to next message
Thanks for the link, Charlie.
That's an excellent resource, particularly in regards to Altec history and driver specifics.
I do want to offer 2¢ worth though. I think some additional comments are in order. For example, the writer indicates that he believes the reflex chamber is "too large" but doesn't specify woofer or tuning frequency. He recommends the 515, but again, doesn't specify tuning. He suggests 12dB/octave crosovers, but would settle for 24dB/octave crossovers instead. These are sort of "seat of the pants" suggestions and I think probably a little more specificity is called for.
The various models of Altec woofers have widely varied electro-mechanical parameters. For example, look at the 515E with Vas of 23.5ft3 compared with the 515-8G with Vas of 12.4ft3. The 416 is different too, with fts tuned nearly an octave lower than most 515's, making the 414-8B or 414-8C most like the 515-8LFE.
Generally, I'd say that the 515-8G is best used in cabinets from 2.0ft3 to 8.0ft3 tuned to 50Hz.
The 416-8B and 8C are best in larger boxes, tuned lower. They work best in cabinets from 5.5ft3 to 18.0ft3 tuned to 30Hz.
You can split the difference and average box size and come up with a 6.0ft3 to 8.0ft3 cabinet tuned to 40Hz for an acceptable compromise, but if you're optimizing parameters, that's not what you're looking for. So I don't think that driver substitution without consideration of cabinet tuning makes sense.
On the subject of crossovers, I probably would not recommend a symmetrical crossover for a loudspeaker like this. The drivers are very different, and they're placed fairly far apart. It is most likely that an asymmetrical crossover would work best. A single frequency 2nd/2nd crossover might be acceptable, but I seriously doubt it will provide the best performance, whether active or passive.
While I would agree that bi-amping is good, I do not agree that passive is necessarily bad. Further, I think the biggest improvement is due to the bandwidth reduction requirements of the amplifiers, not because of improved properties of the crossover and certainly not because of the drivers.
To illustrate, consider these two systems: One is a loudspeaker with a passive crossover using premium components and configured precisely for the system, optimized by modeling and fine tuned with actual measurements. Compare that with the same loudspeaker and drivers, but "upgraded" using an active crossover bought off-the-shelf, with crossover points and slope set by guess.
I don't say these things because I think active units are inferior - far from it - But I think that an optimized passive unit is very good. I've heard plenty of active setups that weren't right, so in my opinion, that's not the holy grail to strive for. It's a means, not an ends.
I think the worst thing about old passive crossovers (and some modern ones) is cheap electrolytic capacitors. Electrolytic capacitiors in passive crossovers should be replaced with polypropylenes or premium electrolytics, like Black Gate N-Types. Make sure any coils used are of adequate size that DC resistance is low. Use air core where possible. If a coil with magnetic core is used, find one that doesn't saturate easily. If resistors are used, be sure they are good quality non-inductive parts and upsize the power ratings. You don't want the resistors to get hot, so use large power resistors.
Another thing about passive crossovers is conjugates. They aren't optional. If the crossover is higher than first-order, a conjugate network must be included, or response anomalies will result. The most noticeable problem is peaking near the crossover frequency. A damping component is required. Lots of speakers don't use Zobels, and I don't think they are installed in stock Altec speakers. But a passive crossover greater than first-order must have a damper or it sounds bad.
There was a figure mentioned in the article for insertion loss of passive crossovers. I think the writer must have just made a guess, but whatever the case, it is wrong. To say that passive crossovers have a 25% insertion loss is just not accurate. As with all things, the performance depends on several factors, configuration, quality and so on.
Measure the low bass from a woofer and then put a low DCR coil in series. Measure the low bass again. You will find that the deepest bass is at the same volume level. Do the same thing with a tweeter using a good quality capacitor, measuring the highest frequencies. The 25% figure of insertion loss quoted is, in a word, wrong. There is more loss from speaker cables, in most cases, especially in installations like theaters with long wire runs.
Switch to an electronic crossover if you'd like. But whether active or passive, some modeling is in order to find the best crossover slope and frequency points. Measure the final result to make its right, tailor if necessary. I think crossover optimization has been overlooked for vintage speakers like these for the most part.
Wayne
And my 2¢ more [message #1836 is a reply to message #1834] Sun, 29 May 2005 13:11 Go to previous messageGo to previous message
spkrman57
Wayne,
Great info, but I have to argue about the stock crossovers not sounding very good due to no zoebel network and using 2nd order crossover topology.
What you say would be closer to truth when using solid state amps, or tube amps with higher power. When a stock A7 (416/802/511/N500) is used with a nice little 45 or 2A3 amp, most of the anomolies don't suface. I know it don't make sense, but I have found the sound to be better with stock crossover than with tweaked out high tech crossovers.
Maybe I just like the mellow/warmish sound that they are so well known for. Now with my JBL 15" (2226) 2-way (Valencia type clone) with Pi speaker crossover for the horn, I will agree it sounds much better, must be something with the 416 drivers that I don't like them w/2nd order crossover and zoebel on them when used with 3rd order Pi crossover on the horn. I don't have a clue why???
Ron
Previous Topic: Sprkman57 Got Me
Next Topic: The latest FM Tuner Shootout review is up
Current Time: Fri Oct 16 14:28:54 CDT 2026
