Home » Audio » Speaker » directivity
Re: directivity [message #18091 is a reply to message #17942] Sun, 07 August 2005 20:02 Go to previous messageGo to previous message
rcw is currently offline  rcw
I have not looked at this forum in a while so didn't see Earl Geddes reply to my post.
Yes I have measured the directivity and in the horizonatal plane it is constant from around 350Hz. in the vertical from around 1200Hz.
The idea behing this is that lateral early reflections are all right since they are processed bi laterally by the ears, but vertical reflections that arrive at the ears vitually simultaniously are difficult to differentiate, this is I am told the basis of the THX 40 degree vertical directivity spec, you seem to have a different opinion.
The work I mentioned is from when Toole was an academic researcher, and is the result of double blind tests that he conducted, apparently in listening to loudspeaker systems with the same overall qualities in terms of linearity and distortion, people prefferd wider dispersion types, to a significant extent.
Previous Topic: Two New Line Array Kits
Next Topic: CSS FR125s project webpage
Current Time: Mon Sep 28 16:33:21 CDT 2026
