Home » Audio » Speaker » Great Plains Audio 704-8A quick notes
Re: Great Plains Audio 704-8A quick notes [message #18082 is a reply to message #18071] Fri, 22 July 2005 08:23 Go to previous messageGo to previous message
Todd W. White is currently offline  Todd W. White
I talked with Jerry Hubbard about it yesterday, and he said that, given the size of the enclosure and the performance parameters of the 704-8A, it COULD be tuned a little lower(it currently has an F3 of 40 Hz), but not much. Therefore, he didn't think it was worth the effort - one could spend more time fiddling with the thing than listening to it...
With regard to the tuning port size/type, we looked at ducted ports, but Jerry pointed out that the speaker only "wants" to see a certain vent size, and doesn't really "care" how you achieve it as much as that it GETS the size it needs and can operate through it without having to work at it.
That said, we figured out it would take THREE large flared ports to accomplish the same thing we did with the horizontal vent, and the cost just didn't outweigh the advantages (if any).
When you listen to the 704-8A in the Stonehenge V enclosure, it performs almost effortlessly in the LF region (it does in the HF region too, but we're not talking about that right now), as does the "G" in the Model 17 and the "H" in the Model 18. So MANY speakers seem to have "work" hard to get the LF out to the listener - the 704-8A in the SH V box doesn't have this problem. In fact, the LF performance is very similar to listen to as the Model 19.
Previous Topic: Modding Some Acoustat Stuff
Next Topic: Line Array woofer system
Current Time: Thu Nov 26 09:42:38 CST 2026
