Home » Audio » Speaker » OS waveguides
Re: Compressiondrivers in general [message #17944 is a reply to message #17940] Tue, 07 June 2005 07:50 Go to previous messageGo to previous message
Martin Goedeke is currently offline  Martin Goedeke
Interresting. The lowest crossover would be determined by power handling and diaphragm Vd then I presume.
So one gets 1.4"-2" drivers that have a nearly planar wavefront or correctly curved wavefront at the throat to enter into a (presumably, or at least in one direction) narrow dispersion horn. Any suggestions as to suitable drivers? (The BMS 4550 is known to be a very, very efficient driver that can be crossed very low for instance and outperforms for eg the B&C DE700 acording to some German designers but you have commented in response to Tom Danley somewhere that they don't strike you as suitable)
3 large format compression drivers per cabinett would be some very narrow dispersion waveguide like in a line-array presumably?
Previous Topic: epiphany model 6-6 /12-12
Next Topic: Linus Array
Current Time: Sun Oct 18 18:25:58 CDT 2026
