Home » Audio » Speaker » Large mid-high horns with an exponential flare
Re: Large mid-high horns with an exponential flare [message #17849 is a reply to message #17840] Mon, 16 May 2005 01:22 Go to previous messageGo to previous message
Peter Krojgaard is currently offline  Peter Krojgaard
Hi colinhester,
I have large, straight bass horns that works up about 300 Hz. These should accompany the mid-high horn.
Although your Edgar horn has a 150 flare rate like the one I am after, your horn can only be used with a cone driver due to it's throat size. I am sure it will sound great as a mid horn:-)
Good luck with it!
Regards
Peter
Previous Topic: DIY Computer Speaker Suggestions Wanted
Next Topic: audax sale
Current Time: Wed Nov 04 15:17:11 CST 2026
