Home » Audio » Speaker » Large mid-high horns with an exponential flare
Re: Large mid-high horns with an exponential flare [message #17847 is a reply to message #17846] Sun, 15 May 2005 23:18 Go to previous messageGo to next message
Yep, Edgar signs all the horns he sells. I suspect he's measured a handful of drivers, so he'll be able to tell you about them. Seems like he does a lot with older EV's and JBL's, but I'm not sure what current production drivers he's used with them. Just have to ask and see.
Re: WOW, Taco Bell does large mid-high horns!?! [message #17848 is a reply to message #17845] Sun, 15 May 2005 23:25 Go to previous messageGo to next message
Audio Asylum is configured to redirect links coming from AudioRoundTable.com over to Taco Bell. To view the post, you'll have to copy-and-paste or type the URL into the address bar on the browser.
Re: Large mid-high horns with an exponential flare [message #17849 is a reply to message #17840] Mon, 16 May 2005 01:22 Go to previous messageGo to next message
Peter Krojgaard is currently offline  Peter Krojgaard
Hi colinhester,
I have large, straight bass horns that works up about 300 Hz. These should accompany the mid-high horn.
Although your Edgar horn has a 150 flare rate like the one I am after, your horn can only be used with a cone driver due to it's throat size. I am sure it will sound great as a mid horn:-)
Good luck with it!
Regards
Peter
Thanks to all of you for your responses! (nt) [message #17850 is a reply to message #17836] Mon, 16 May 2005 01:24 Go to previous messageGo to next message
Regards
Peter
Re: Large mid-high horns with an exponential flare [message #17851 is a reply to message #17846] Mon, 16 May 2005 08:42 Go to previous messageGo to next message
We do it all then we die. So Colin; exactly how many huge speakers will you have to get past your wife into the house?
The Kids could always use them to play in.
See Honey; they're playhouses. With sound systems in 'em.
Re: Large mid-high horns with an exponential flare [message #17852 is a reply to message #17851] Mon, 16 May 2005 09:20 Go to previous messageGo to next message
At 50% capacity (this is about what Ron has) and assuming each pair of cabs takes up 20 sq. feet, I could easily fit about 1400 pair. However, two pairs is about my wife's limit.
You're right. This would make a really fun play house for the kids; however, McDonald's has a nice playland right down the street, and it would be cheaper to just buy the store.....Colin
Re: WOW, Taco Bell does large mid-high horns!?! [message #17853 is a reply to message #17848] Mon, 16 May 2005 09:29 Go to previous messageGo to next message
GM is currently offline  GM
Greets!
Really! Oh well, at least you can copy/paste the link to get there.
GM
Re: Large mid-high horns with an exponential flare [message #17854 is a reply to message #17852] Mon, 16 May 2005 11:13 Go to previous messageGo to next message
If my wife saw those coming in the door; I'd be listening with her lawyer.
Re: Large mid-high horns with an exponential flare [message #17856 is a reply to message #17851] Mon, 16 May 2005 19:28 Go to previous messageGo to next message
Its a pity [message #17857 is a reply to message #17853] Tue, 17 May 2005 15:49 Go to previous messageGo to previous message
That a place with such knowledge tidbits are buried so deeply under lots of stuff.
Equal potential for good and bad - More power,more potential.
Previous Topic: DIY Computer Speaker Suggestions Wanted
Next Topic: audax sale
Current Time: Sat Nov 07 04:21:53 CST 2026
