Home » Audio » Speaker » Checking with meter
Re: Checking with meter [message #17765 is a reply to message #17762] Tue, 26 April 2005 03:39 Go to previous messageGo to previous message
When you measure with a meter, what you see is DC resistance and that's only part of impedance. The other part is voice coil reactance, and that won't show up on a meter. Typical DC resistance value for an 8 ohm driver is 4-6 ohms, for a 16 ohm driver it's usually 8-12 ohms. Some are a little higher or lower.
Previous Topic: neat trick for corners in rear horns, xmission lines
Next Topic: I need help in the creation of a midbass horn...
Current Time: Fri Nov 06 01:20:25 CST 2026
