Re: So you are saying [message #17602 is a reply to message #17599] |
Mon, 28 February 2005 11:29 |
Earl Geddes
Messages: 220 Registered: May 2009
Master |
I have done some tests on the BMS drivers and don't find that they actually do have much more HF content. In the coaxial drivers the response at the crossover is a mess, and this is in a critical band for audibility. I have looked at just about every driver ot there and B&C is my choice. I am looking more seriuosly at Beyma, but BMS is not in the running.
Re: So you are saying [message #17603 is a reply to message #17598] |
Mon, 28 February 2005 11:36 |
Earl Geddes
Master |
First I ballpark the design by calculating what a 15" piston directivity would be and what a waveguide should be to match at 90°. Then I set up the system and measure the complete polar response of both drivers in the actual enclosure. Finally a crossover is designed and optimized with a computer program that I wrote to give the flatest response over all angles in the forward 90° arc, with a slight preference for 22.5° (the direct angle). Finally, of course, the crossovers and systems are tested at all polar angles (these results are shown on my web site). I have never seen a situation where the measurements and computer predictions were not the same, so this last step is a simple confirmation.
Re: I checked up Floyd Toole's work [message #17604 is a reply to message #17600] |
Mon, 28 February 2005 11:42 |
Earl Geddes
Master |
So then you have to ask yourself why there are so few constant directivity designs available. Maybe its because they are hrd to do? Please keep in mind that omni IS constant directivity. Its constant high directivity that is the key. If you have not heard a good narrow constant directivity loudspeaker then do yourself a favor and hear them. You won't like anythiing else again. I would suggest mine.
CD versus H/LD [message #17607 is a reply to message #17604] |
Mon, 28 February 2005 14:32 |
akhilesh
Messages: 1275 Registered: May 2009
Illuminati (3rd Degree) |
Earl, I hope you do come to Tulsa for the spring Audio fest, becuase I would love to hear your designs! I did some more thinking on this, and i agree: i was confusing constant dir (CD) (varies with frequency) and high versus low directivity (h/LD) (varies with degree) , as you said in your post. On re-reading Floyd's white paper, it seems he is saying one wants CD, but says nothing about LD versus HD. Clearly, HD (along with CD) will mean that the primary sound will dominate the musical energy, as opposed to first order and second order reflections. In other words the waterfall plot will slope much more with HD. Do you have any studies at GEDLEE that have established, in double blind tests, that HD is preferable to LD, CD being held constant? Intuitively I agree with you: HD will make the room sound "deader" than LD. Hope to see you in tulsa -akhilesh PS: Do you offer your speakers for sale or on a trial basis?
Re: CD versus H/LD [message #17610 is a reply to message #17607] |
Mon, 28 February 2005 14:54 |
Earl Geddes
Master |
No - we only did studies of HD CD comparisons with different speakers. But here is the thing to consider with HD. With HD I can point the speakers such that the early reflections are minimizes and so that the first reflections come to the ear opposite the first arrival. This is very important since a first arrival and an early refelction at the same ear will cause coloration. This is point one. Now also consider the energy time arrival of an HD versus a LD. The LD reflections arrive almsot instantaneously there is not gap between the first arrial and the early reflections. Not so the HD. There is a significant gap between the first arrival and the early reflections. I cannot overstate how important this later aspect is to imaging. Without a gap in the arrival times of the direct sound and the early reflectiosn the ear cannot resolve spatial location cues and the imaging will be poor. The imaging on my speakers is as precise as headphones but without the "in the head" image problem. Pinpoint locailzation in a space beyond the actual location of the speakers. It really has to be heard to be believed.
Re: CD versus H/LD [message #17611 is a reply to message #17610] |
Mon, 28 February 2005 15:49 |
akhilesh
Earl, Thanks for your reply. I agree with you...intuitively it makes total sense: HD will lead to better imaging, and a cleaner sound. Since you have the setup & the skills, i was speculating that it would be interesting to measure, in a double blind test, if (educated) listeners (a la Floyd Toole's methodology) actually do prefer HD, and by how much (keeping CD & the rest of the room & system constant of course). Speculating further, we'll have to figure out how to develop 2 speaker systems, one with HD & one with LD, with CD constant. ALternately, one could use the same speaker system, but in one experimental tresatment emphasize room reflections so they are stronger and reach the listener sooner. Should be interesting & fun! Not to mention a good potential AES paper! -akhilesh
