Home » Audio » Speaker » Distortion mechanisms
Re: So you are saying [message #17599 is a reply to message #17597] Mon, 28 February 2005 10:52 Go to previous messageGo to previous message
Mark Seaton is currently offline  Mark Seaton
Earl Geddes wrote:
"I am not aware of any work that Floyd did saying the omni-speakers are prefered. That would not agree with JBL's trend to make their loudspeakers directional. In their extreme high end system they basically do the same thing that I do. Only thiers cost ten times as much!"
Actually Earl, that should read "They are *charging* 10 times as much." Because they can! Of course those Berrilium diaphram compression drivers are certainly a bit more expensive than is warranted.
Out of curiosity, Earl, have you measured or listened to the BMS 1" exit or their larger coax compression driver? Do you consider the slight increase in their high frequency extension to be of much value beyond marketing?
Regards,
-Mark Seaton
Previous Topic: Vott 210 and slot cars
Next Topic: Pro Sound Driver Sensitivity
Current Time: Mon Nov 16 07:10:03 CST 2026
