| Distortion mechanisms [message #17575] |
Wed, 23 February 2005 15:41  |
Messages: 19107 Registered: January 2001
Earl Geddes and I were discussing various distortion mechanisms, both on and off forum. I wanted to bring the discussion out in public I think most will find it interesting and because I'd like to hear other's opinions too. Some of you have done a lot of thinking on these matters, and some have done some work and models and measurements.One thing that comes to mind is Geddes opinion that second and third harmonic distortion from loudspeakers is not as objectionable as higher harmonics. I think he's probably right. I think measurements of second harmonics are still pretty good information, since they are easy to make and they indicate asymmetry. That will also introduce other even harmonics and the ones higher up in frequency may be the ones that are really noticeable, even if at lower amplitudes. Something else that comes to mind is the matter of nonlinear distortions verses linear distortions. That is something Geddes brings up a lot, and was also mentioned recently by Dave Williams. My thinking is that efficient, powerful speakers used at home hifi levels are probably used pretty much in the linear regions, at least where electro-mechanical properties like suspension stiffness and voice coil resistance and motor strength are concerned. I think the mathematical models are useful. I don't think it is wise to assume perfectly pistonic behavior of the diaphragm, perfectly resistive impedance of the voice coil or perfectly linear excursion of the motor. It is good to realize that isn't the case, and to take it into account when making a design. But the models that make those assumptions are useful tools. I also think that it is worthwhile to design systems that are very tolerant of parameter shifts because they're going to happen. And I think that doing things to reduce the things that cause nonlinear distortion is always good too. But first, you must define them and know what they are to begin dealing with them. There are many other distortion mechanisms too. There is throat distortion, caused by the nonlinearity of the air in extreme compression/rarefaction cycles. There are the high order modes that Geedes often focuses on. There is doppler distortion from moving diaphragms. There is intermodulation distortion. There is compression. Then there are other nonlinearities that don't have specific names. There is the modification of waveforms in some capacitors such as electrolytics and ceramics. There is the effect produced by a coil or transformer in magnetic saturation. There are the changes of a conductor when hot. Or of a semiconductor, like the carbon in resistors or the silicon in transistors. There is the non-uniformity of magnetic flux at the edges of travel in a loudspeaker, and the asymmetry produced by flux modulation. What do you guys think? Lots of things to consider here.
| Re: Distortion mechanisms [message #17576 is a reply to message #17575] |
Wed, 23 February 2005 18:05   |
Mike.e
Messages: 471 Registered: May 2009
Illuminati (1st Degree) |
I think that we need a methodical approach,attacking the main offendors first rather than attacking the easy problems which have little effect.Polar response and crossover/driver interactions especially[as stated in SB1980 - Linkwitz]where he advocated 4th order LR filters and acoustic axis issues. What we have at the moment is an interesting market. The 'hifi' market that you see in the stores,and the 10% of those who are simply not happy with those products,be they engineers,enthusiasts,musicians or anything. The vast majority are happy with these cheap system until they hear better, so the real 'hifi'owners will always be a minority group. I feel that the real improvements will always come through the prosound area and that there will always be the people who are happy with their technically bad, but subjectively good {to them atleast}sounding systems. Once into this group theres so many ways to go,but to me theres 2 main branches each aiming at different goals. the low efficiency omnidirectional guys,and the directional high efficiency guys. These to me seem to be opposite and equal but just 2 extremes of the audio pie full of varying flavours! One cant be better than another,and aslong as people admit where they are measurement wise and arent operating in a physics free world I dont mind if they listen through 5" fullrangers or MTM d appolito 2ways.. Cheers! Mike.e
| Re: Distortion mechanisms [message #17578 is a reply to message #17576] |
Wed, 23 February 2005 19:17   |
Earl Geddes
Messages: 220 Registered: May 2009
Master |
I think that I must disagree with the comment about omin directional versus directional - that they are just two different approachs. This is not correct. In an anechoic chamvber, yes, they are both the same with the listener receiving only the direct sound. Bt in a normal room with reverberation they are dramaticaly different. The omni has no reflection free time lag after the direct sound while the directional speaker does - if pproperly aimed. This is not a small effect either, it is almost dominat to imaging and coloration. So, no, I don't agree with your comment.
| Re: Distortion mechanisms [message #17580 is a reply to message #17575] |
Thu, 24 February 2005 12:42   |
akhilesh
Messages: 1275 Registered: May 2009
Illuminati (3rd Degree) |
HI Wayne, I agree, higher order distortions are more irritating, since htey are further from the fundamental. http://www.pmillett.addr.com/file%20downloadss/1 has a great slide show. Here is a good primer on distortion in general, with a cool applet. http://www.mindspring.com/~j.blackstone/dist101.htm -akhilesh
| Clarification [message #17582 is a reply to message #17578] |
Thu, 24 February 2005 14:08   |
Mike.e
Hi Earl My intention was to say that the two approaches are opposite and produce rather different results in room. Is this your opinion also? Whether one is more correct than the other... Perhaps my NZ english prevents me from understanding quite what you mean in this sentance below  Regards Mike.e omni has no reflection free time lag after the direct sound while the directional speaker does - if pproperly aimed
| Re: Clarification [message #17583 is a reply to message #17582] |
Thu, 24 February 2005 14:52   |
Earl Geddes
Master |
This is a very complex phenomina, but absolutely the key to why directional sources sound better in rooms than non-directional ones. Picture an omni source - it hits all the walls, near far what ever, on the first wave. Now picture the directional source, picture it very narow, like a beam of light. It hits only one wall on the first pass, another on the second, maybe two, its at least three or four reflection before the reverb field begins to build. The omni happens immediately. This takes a lot of thought, but think it through and you'll see what I mean. So I am saying that one type is definately better than the other.
| Re: Clarification [message #17584 is a reply to message #17582] |
Thu, 24 February 2005 15:07   |
Earl Geddes
Master |
I should also add the subjective nature that makes this delay necesary. The ear integrates over a period of time. The time is variable with frequency but it has a typical value of 10 - 20 ms. The more reflections that arrive in this time period the more difficulty the ear has determining an unambiguous sound localization. Thus this first few ms. is critical to imaging and coloration of a loudspeaker. Sure the room can help, but in small rooms the lodspeaker and room must both be done correctly to get the best imaging and sound quality. Neither one alone can do it.
