Home » Audio » Speaker » Favorite flavors
Favorite flavors [message #17422] Fri, 21 January 2005 13:54 Go to next message
I'm looking to get some opinions on favorites, specifically horn shapes and dispersion patterns. Or, for that matter, if your favorite configuration isn't a horn, I'd like to hear those opinions too. But more importantly, I'm looking for your reasons why you like that particular horn, shape or speaker configuration.
My favorites are horns with fairly wide dispersion. I don't particularly care for horn setups (or any kind of speaker, for that matter) that requires the listener to be in a very small "sweet spot." When I listen to a system, I rarely sit exactly on-axis, and sometimes the owner will instruct me to move into the preferred spot. But I am actually sitting there because I judge a system by off-axis performance as much as any other attribute.
To me, part of the goal is to make the system sound as good 10°, 20° and even 30° off-axis as it does on-axis. I am looking for a speaker that charges the reverberent field uniformly because it sounds far more natural than one that doesn't, in my opinion. If you have to sit in a half-meter wide sweet spot for the system to sound good, I'm not particularly impressed.
I know that some, if not most, audiophiles expect the listener to be seated in that one "perfect spot." Why would someone settle for only having good imaging and proper tonal balance in a "sweet spot" when they can have that same kind of performance over a wider range? I expect this kind of thing from planars and soft domes, but from horns? I see it as a throw back to technologies of 50 years ago. A good horn system has directionality that controls the pattern and fills the room without excessive wall and floor reflections. Horns offer a possibility of creating a good field of sound instead of a good line of sound.
So that's the flavor that gets my vote. I like horns, and I like them designed to cover the room. In addition to tonal balance and low distortion, a uniformly charged reverberent field is very important to me.
Chocolate [message #17423 is a reply to message #17422] Fri, 21 January 2005 16:31 Go to previous messageGo to next message
Re: Chocolate [message #17424 is a reply to message #17423] Fri, 21 January 2005 16:57 Go to previous messageGo to next message
Re: Favorite flavors [message #17425 is a reply to message #17422] Fri, 21 January 2005 20:19 Go to previous messageGo to next message
My single favorite aspect of Horn loaded designs; the singers are properly placed in the mix. I find with direct radiators they emphasize the vocals and soloists in an unnatural forward thrust that gets annoying. The Pi 4's arrange music in a much more realistic manner. I can't say exactly what the dispersion pattern is but one thing I notice is they even sound natural listening from another room.
Can't say how many times people comment on that very fact.
Some albums that sounded as if the singer was twenty feet into the room now attain their rightfull position on the stage.
Another thing; pet peeve, is what the attraction is with single drivers. I don't get it. everything sounds like it is on one plane and the same hieght or position. My 2c.
Re: So true about single drivers, but.... [message #17427 is a reply to message #17425] Sat, 22 January 2005 05:20 Go to previous messageGo to next message
.....one of the 2 things I like about them. So that's a flavor thing, too. I refer to the:
"everything sounds like it is on one plane and the same hieght or position. My 2c."
I liked the way the musical image floated between, away and around the FE104 speakers.
Here's another FLAVOR: of those who have horns, how many, like me find the soundstage airier, deeper and more "realistic" with LP's rather than CD's? Not a subtle but a gross difference?
Back on point, my own favorite horn flavor is the amazing clarity that results from low distortion and freedom from cabinet colorations. That, combined with the ability to faithfully portray dynamics makes horns sound so "Effortless".
Re: So true about single drivers, but.... [message #17428 is a reply to message #17427] Sat, 22 January 2005 07:29 Go to previous messageGo to next message
Tend to find everything airier and deeper and more realistic with LP's on every speaker type. True; much more dynamics and while it's hard to tell distortion products in a relatively small room, they do sound cleaner and more musical at low volume than many of the direct driver speakers have.
Id really love to try all at the same time! [message #17430 is a reply to message #17422] Sat, 22 January 2005 08:01 Go to previous messageGo to next message
And just see what sounds best,and compare that to my knowledge of systems and how they are in theoretical terms and measurements!
Until I build them myself however I wont be able to- my city/country has so little audio nuts like myself!
-Perhaps when im finished studying and earning il be finally able to sort this out!
Cheers
Mike.e
Re: amazing clarity... [message #17437 is a reply to message #17427] Sat, 22 January 2005 13:59 Go to previous messageGo to next message
That's why I'm an open baffle convert.
But I haven't heard a speaker that will do justice to everything. For instance, I like Khorns best for large orchestral music, but for “small” music they don’t seem very realistic. Since I listen to a lot of jazz combo, I like open baffles these days. Horn-over-reflex speakers (e.g. Pi speakers) seem to be the only thing for rock-n’-roll.
If I were Bill Gates I’d have the same size house, but many different spaces with many different set-ups.
more realistic with LPs [message #17438 is a reply to message #17428] Sat, 22 January 2005 14:05 Go to previous messageGo to next message
I have a commercial CD that was transcribed from a commercial issue LP. They say in the liner notes that there are no tapes available, so they got the best condition LP they could find and recorded the CD from that.
The funny thing is that the CD sounds so LP - you'd swear you're listening to an LP.
I have no idea what that effect is, but it made it clear to me that CD and LP can certainly sound the same if that's your objective.
Re: more realistic with LPs [message #17439 is a reply to message #17438] Sat, 22 January 2005 14:27 Go to previous messageGo to previous message
Yeah; the Mosaic Jazz series has that effect. Really don't know how or why but even trying comparisons between the same LP and CD they sound very close.
Previous Topic: correction filter for Fostex fe206e in a Jeriko
Next Topic: Thoughts on focused arrays and the phase problem
Current Time: Sun Nov 29 13:48:56 CST 2026
