Home » Audio » Speaker » E130-8 horn load or 2 on open baffle or K-Horn?
E130-8 horn load or 2 on open baffle or K-Horn? [message #17356] Fri, 14 January 2005 07:05 Go to next message
adavis464 is currently offline  adavis464
If I take 1 and horn load it I get 105db to 106db.But if I take 2 on large open baffle I would get about the same spl.I also think a K-Horn is about the same.I've never heard a k-horn I have heard sealed and vented and bandpass.Or should I try all 3 and make my own mind up.K-horns sound intresting but no one sames to know how they work.Some I've seen like magnetars (rosie)But I think he just placed a exponetial curve cutout in front of a woofer box and they work as k-horns?I need a quality midbass solution.100hz 600hz or higher. thanks Tim
Re: E130-8 horn load or 2 on open baffle or K-Horn? [message #17366 is a reply to message #17356] Sat, 15 January 2005 01:29 Go to previous messageGo to next message
You intend to use these for MI? Realize that the E-130 is not intended for reproduction. Bill Fitzmaurice says it will work well in his DR-15.
When people speak of a "K-horn" they almost invariably mean a Klipshorn. Rosie is not a K-horn, it's a Karlson Coupler (Google Karlson and you'll find a web site devoted to it; Freddy Ireson is a contributor there).
From my reading (no direct experience) I suspect the Karlson has a resonance in the 50-70 Hz range that gives the impression of hard-hitting bass response. I'm not sure you'd benefit above 100 Hz.
HTH
The DR-15 [message #17367 is a reply to message #17366] Sat, 15 January 2005 01:32 Go to previous message
http://www.billfitzmaurice.com/plans/product_info.php/products_id/2
Previous Topic: Coral Beta 6 in Ebay
Next Topic: Power tapering Idea - Mass loading ?
Current Time: Sun Nov 22 22:09:56 CST 2026
