Home » Audio » Speaker » Hi-Efficiency vs Lo-Efficiency Speakers
Re: Hi-Efficiency vs Lo-Efficiency Speakers [message #17334 is a reply to message #17333] Mon, 10 January 2005 11:28 Go to previous messageGo to previous message
Hi Earl,
Shorting rings are used to make motor movement more symmetrical, as you know. I have only seen evidence that this reduces even harmonics, i.e. 2nd, 4th, etc. Speaking only of harmonic distortion, are you saying that you believe odd harmonics are reduced too?
Other non-linearities are present in the system, to be sure. At high power levels in particular, there are many other matters than just push-pull flux symmetry. But push-pull symmetry is what the shorting ring is used for. Can you think of other benefits it may bring?
Wayne
Previous Topic: fostex rear loaded horn design
Next Topic: Coral Beta 6 in Ebay
Current Time: Fri Nov 06 02:48:59 CST 2026
