Home » Audio » Speaker » Geddes Waveguide
Geddes Waveguide [message #17074] Tue, 12 October 2004 13:44 Go to next message
Paris is currently offline  Paris
I am intrigued by Geddes horn philosophy. Horns like this seem to be a wave of the future. Let me quote Geddes. He says, the goal is smooth constant directivity over a prescribed angle. Most CD horns use a diffraction slot to obtain polar control, however, diffraction gives rise to periodic peaks and dips in the response at all angles because of standing wave created from the wavefront reflection at the point of the diffraction. It is well known that diffraction less horns, like tractrix have superior sound quality, but they lack directivity control. The goal then is directivity control without diffraction. The holy grail would seem to be CD horns without diffraction. Maybe tractrix and other horns like it are obsolete?
Re: Geddes Waveguide [message #17077 is a reply to message #17074] Wed, 13 October 2004 17:56 Go to previous messageGo to next message
hmm i dont know enough about HF horns to comment..
Read something like the jbl4430 manual -which describes DI and all sorts and says exactly why there product is good.Also many graphs and diagrams.
Re: Geddes Waveguide [message #17083 is a reply to message #17074] Fri, 15 October 2004 16:47 Go to previous messageGo to next message
Mark Seaton is currently offline  Mark Seaton
Has anyone ever seen this waveguide? I can't even find a verbal description anywhere.
-Mark Seaton
Re: Geddes Waveguide [message #17268 is a reply to message #17083] Thu, 23 December 2004 21:35 Go to previous messageGo to next message
There is more to my theory than simply the shape. All of this is well documented in my book or in AES papers and the like. Its not new at all, nearly twelve years old at this point.
Re: Geddes Waveguide [message #17292 is a reply to message #17268] Mon, 03 January 2005 05:11 Go to previous messageGo to next message
Thanks for writing here. From what I gather, you don't like the dispersion of tractrix horns, and don't like response of CD horns. Is that about it? What about a combination of the two, a CD horn with a radiused edge? That's what your prototype looks like it uses. Is that what you propose, in a nutshell?
Re: Geddes Waveguide [message #17293 is a reply to message #17292] Mon, 03 January 2005 07:59 Go to previous messageGo to next message
I don't think my point is that black and white, but yes, I think that things can be improved over Tratrix and CD horns. Mine are not simply classical CD horns with a radius'd edge. Its not quite that simple.
Re: Geddes Waveguide [message #17306 is a reply to message #17293] Thu, 06 January 2005 05:08 Go to previous messageGo to next message
Would you care to elaborate? I am most interested in your design concepts and want to know more. Are your speakers for sale anywhere now? Where can they be auditioned?
Thanks in advance.
Re: Geddes Waveguide [message #17307 is a reply to message #17077] Thu, 06 January 2005 05:14 Go to previous message
Look at the polar response of the Geddes speaker at the link. From what I know, it uses the narrowing DI of the woofer to match the waveguide at crossover for very smooth polar response. The waveguide has constant DI, so it is EQ'd in the crossover for flat power response. Isn't that about right, Dr. Geddes?
Previous Topic: Do more sensitive drivers offer less distortion at "normal" listening levels?
Next Topic: Fluance Speakers
Current Time: Wed Oct 14 12:40:39 CDT 2026
