Home » Audio » Speaker » Do more sensitive drivers offer less distortion at "normal" listening levels?
Another perspective [message #17267 is a reply to message #17133] Thu, 23 December 2004 21:25 Go to previous messageGo to previous message
After numerous studies of nonlinear distortion, in loudspeakers and otherwise, I have concluded that nonlinear distortion is not a primary factor in sound quality. This agrees with the work of Shawn Olive at Harman.
What, IMO, does make a difference - directivity. Most High efficiency loudspeakers are more directional because they tend to be bigger. This directionality helps to minimize room refections and diffractions which are audibly very negative factors. But high directivity in and of itself is not enough, it must also be well controlled. Both the direct response and the power response have to be equal and this must be done with a high degree of directionality to achieve good imaging and presnce. but the room itself must also be done right or the loudspeaker won't make a whole lot of difference.
No, I don't think that its the high efficiency of larger drivers and waveguieds that matter, but it is there inherent narrower directivity that is the primary factor.
Previous Topic: Last question, I promise! (I'm lying)
Next Topic: Geddes Waveguide
Current Time: Sat Nov 28 22:35:55 CST 2026
