Home » Audio » Speaker » vitavox woofer MM380, music motor, cases, thile small params
vitavox woofer MM380, music motor, cases, thile small params [message #17210] Sun, 28 November 2004 05:50 Go to next message
sali@brasil is currently offline  sali@brasil
Hi
i have some 15" woofers of vitavox with name MM380 (music motor 380).
Now i am searching for the thile small parameters and for the
some building plans of cases for this driver.
Thanks in advance
Sali
ThieleSmall.com [message #17212 is a reply to message #17210] Mon, 29 November 2004 09:46 Go to previous messageGo to next message
Sorry to disappoint you, because the electro-mechanical parameters for your Vitavox drivers are not in the database at www.ThieleSmall.com. But I thought you might be interested to know about this database anyway.
You might measure the specs and submit them there. All you'll need is a PC, sound card and a good DVM.
Re: ThieleSmall.com [message #17236 is a reply to message #17212] Sat, 11 December 2004 14:45 Go to previous message
Thank you, i will try to mesaure the specs, when i have done
i will add them to your database.
Previous Topic: ESS AMT 1A - need practical advice.
Next Topic: Loudspeaker re-design help needed!
Current Time: Fri Nov 13 08:10:39 CST 2026
