Home » Audio » Speaker » JBL polarity
JBL polarity [message #17143] Sat, 30 October 2004 17:53 Go to next message
Kennedy is currently offline  Kennedy
I was told JBL speakers connect [+] black and [-] red. Is this true?
I guess that is ok if you use all JBL but if you mix brands your in trouble.
Re: JBL polarity [message #17144 is a reply to message #17143] Sat, 30 October 2004 18:11 Go to previous messageGo to next message
Some are like that and some aren't. Consult the document at the link below to find out which is which.
Re: JBL polarity [message #17152 is a reply to message #17143] Thu, 04 November 2004 15:18 Go to previous message
Reversing the polarity should be a simple matter. Back in the day current was thought to be + to - ,infact its not. Electron flow is from -ve to +ve
But alotof things this wont effect aslong aslong you keep using the same arbitrary value.
Previous Topic: radio shack goodies
Next Topic: Scan Speaks
Current Time: Sun Nov 08 19:42:04 CST 2026
