Home » Audio » Speaker » Horns and Room Size
Re: Practically [message #17103 is a reply to message #17099] Fri, 22 October 2004 10:31 Go to previous messageGo to next message
tuber is currently offline  tuber
of course. how could i have missed that.
Re: M [message #17104 is a reply to message #17100] Fri, 22 October 2004 10:32 Go to previous messageGo to next message
link?
Re: I don't use M values in my sub horns, [message #17105 is a reply to message #17101] Fri, 22 October 2004 10:35 Go to previous messageGo to next message
what profile do you use?
Re: I don't use M values in my sub horns, [message #17106 is a reply to message #17102] Fri, 22 October 2004 10:39 Go to previous messageGo to next message
indoors? outdoors? it is important for comparing different size and shape horns, no? not one size fits all.
Re: I don't use M values in my sub horns, [message #17107 is a reply to message #17106] Fri, 22 October 2004 11:05 Go to previous messageGo to next message
pgolde is currently offline  pgolde
Both outdoors (small parties, not festivals) and indoors in rooms for for 100 or so people. The horns are replacing dual 18's. I also listen to them at home (background music for building new speakers)
Ooops [message #17108 is a reply to message #17104] Fri, 22 October 2004 11:43 Go to previous messageGo to next message
Dinsdale,Edgar files -very important
No magic just different compromises [message #17109 is a reply to message #17102] Fri, 22 October 2004 11:47 Go to previous messageGo to next message
The rules havent changed nor the physics-just different ways of squeesing what we want from higher spec drivesr on an optimal horn.
The labhorn is quite cool and amazing FREE! design considering an off the shelf 'normal' woofer *although it has ideal horn specs* its just your average 12"
Bdeap is so magical you cant build it anyway (patented)-youd have to buy one (oops i mean buy many many of them to achieve the desired output just like many labhorns are required)
The only thing which you could do is put a 15" on a horn and fold it simple S fold style like mine!!!
Cheers!
Re: I don't use M values in my sub horns, [message #17110 is a reply to message #17109] Fri, 22 October 2004 13:11 Go to previous messageGo to next message
I am using 15's for midbass. I dont think a hornsub with a 15 inch driver would be the best use of space. I like the idea of smaller less expensive drivers, longer horn path. The Tuba doesnt seem to waste a lot of space with a large flare opening, The B-Deap uses the outside of the box and surrounding walls and floor as the flare.
Re: I don't use M values in my sub horns, [message #17111 is a reply to message #17105] Fri, 22 October 2004 14:17 Go to previous messageGo to next message
My own. It's nothing that can't be reverse engineered easily enough but I'm not going to give it away.
Re: I don't use M values in my sub horns, [message #17112 is a reply to message #17102] Fri, 22 October 2004 14:20 Go to previous messageGo to previous message
A Tuba 24 won't equal a Lab, but that doesn't mean it might not be enough to do the job for you. Tuba 30 will give the Lab a run for its money, is smaller, a lot easier to build and uses only one driver to boot.
Previous Topic: Scan Speaks
Next Topic: Need Dynaudio Gemini speaker plans and suggestion?
Current Time: Fri Nov 13 08:34:18 CST 2026
