Home » Audio » Speaker » mid range drivers - what options for cone driven horns?
mid range drivers - what options for cone driven horns? [message #17087] Sat, 16 October 2004 19:48 Go to next message
brw is currently offline  brw
getting to the point of wanting to redo my compression mids. cant drive them low without stress.
could go high$$$ but instead want to use cones on straight wall horns. what mid range drivers sound best?
Re: mid range drivers - what options for cone driven horns? [message #17088 is a reply to message #17087] Sat, 16 October 2004 21:15 Go to previous messageGo to next message
I'm really enjoying JBL 2012's and Eminence neodymium (and ferrite) Delta 10's. But there are plenty of others too, and I'm sure people will sound off with other good suggestions.
Re: mid range drivers - what options for cone driven horns? [message #17089 is a reply to message #17087] Sun, 17 October 2004 03:27 Go to previous messageGo to next message
It depends what you want - How large can the horn be in mouth area and length at maximum? What lower and upper cutoff points do you want? What sensitivity do you require? And what maximum output? How much can you spend per driver?
Re: mid range drivers - what options for cone driven horns? [message #17146 is a reply to message #17089] Sun, 31 October 2004 09:35 Go to previous message
Jeff Robinson is currently offline  Jeff Robinson
I don't know what BRW wants, but MY wish list is: mouth area ~1161 in^2 (43" x 27"ID, smaller would be nice), throat length 38 inches (shorter would be nice), -3dB points 100 Hz & 600 Hz (wider bandwidth would be nice), 106 dB/w, 130+ dB sustained output. I like EV's EVM10M and DL10X but would consider other comparable woofers from JBL, B&C, Beyma, 18Sound, PHL, Eminence, etc.
Jeff Robinson
Previous Topic: A project to finish up MLTL Fostex FE127e
Next Topic: Tapering--- can someone clue me in on this?
Current Time: Wed Nov 04 07:57:35 CST 2026
