Home » Audio » Speaker » Ferguson Hill - Clear Horns
Ferguson Hill - Clear Horns [message #17075] Wed, 13 October 2004 13:19 Go to next message
Greg Lytte is currently offline  Greg Lytte
Have any of you listened to these speakers? Is there a place to demo them in the US?
It is a very large and pretty bell. How do they keep the bell from ringing without bracing of any kind?
Re: Ferguson Hill - Clear Horns [message #17078 is a reply to message #17075] Thu, 14 October 2004 07:02 Go to previous messageGo to next message
The 'bell' doesn't ring because there isn't anybody whacking it with a hammer. This shape is particularly resistant to mechanical vibration, and requires no bracing because there is no rear chamber behind it which could serve as a source of frequencies that could vibrate the structure. This rig is functionally identical to a small horn-loaded tweeter, just a lot bigger.
Your concern falls into the same category as the persistent myth about metallic radiating surfaces, cone or dome or whatever, having a 'metallic' sound. They don't, because again they aren't being struck with anything, they are simply moving back and forth as pistons.
I haven't heard these but they do look nice.
That really doesn't seem to hold water [message #17079 is a reply to message #17078] Thu, 14 October 2004 17:55 Go to previous messageGo to next message
A bell "rings" as it vibrates at its fundamental resonance. The clear bell, or any horn, is quite capable of having its first resonance excited by the acoustic wave it is conducting.
Describing it as "metallic" may be inaccurate, or reflect a prejudice, but the resonance can certainly exist.
Re: That really doesn't seem to hold water [message #17080 is a reply to message #17079] Fri, 15 October 2004 06:37 Go to previous message
Of course, and it is required that the natural resonance modes of the structure not be excited by program material to the point that they are audible. But that caveat applies to any enclosure, irrespective of shape or design. If anything the shape of this or any bell is less likely to have serious peaked resonant modes than a structure with flat surfaces.
Previous Topic: need plans in "inches" for Lowther DX-3 back horn cabinets
Next Topic: List of popular speakers
Current Time: Sun Oct 25 00:42:21 CDT 2026
