Home » Audio » Speaker » How low will this horn go
How low will this horn go [message #17025] Mon, 04 October 2004 10:52 Go to next message
Klaus is currently offline  Klaus
Hello everyone,
Please forgive my poor english I am German.
I want to use only the basshorn part of my Yamaha S5115HT speakers.
They are like the Altec VOT with a bass horn that is also vented using a 15inch speaker.
I will not use the vented part but add a back chamber to the horn.
The horn mouth is 26,5 inch x 22,5 inch. Depth is 14 inch. The throat is about 12inch in diameter with slightly flat top and bottom.
How low will this horn go?
Is 160 hz possible?
Thanks,
Klaus
Re: How low will this horn go [message #17027 is a reply to message #17025] Mon, 04 October 2004 11:23 Go to previous messageGo to next message
Julenk is currently offline  Julenk
Id say 200hz is prolly as low as you should xpect.
Re: How low will this horn go [message #17037 is a reply to message #17025] Tue, 05 October 2004 07:08 Go to previous message
A 14 inch pathway will support a potential Fc of 242 Hz. The horn will pass frequencies below that in direct radiator mode. I personally don't think a 242 Hz Fc makes sense with a 15 inch driver when the same could be accomplished with an eight.
Previous Topic: Jim Griffin
Next Topic: folded horn midrange
Current Time: Fri Nov 13 08:16:12 CST 2026
