Home » Audio » Speaker » Altec 414
Altec 414 [message #16975] Mon, 13 September 2004 14:20 Go to next message
VOTTica is currently offline  VOTTica
What would you do with an Altec 414? What size box, crossover, etc?
(((VOTTica)))
Re: Altec 414 [message #16976 is a reply to message #16975] Mon, 13 September 2004 15:58 Go to previous messageGo to next message
The specs suggest it would be best as a midbass driver crossed over highpass at 100Hz or as a woofer in a horn, with the size of the horn pretty much determining how low it can go. You should download the WinISD and HornResp freeware programs; that driver is in the WinISD data base and it gave me this answer in less then thirty seconds,
Re: Altec 414 [message #16981 is a reply to message #16976] Tue, 14 September 2004 16:28 Go to previous messageGo to next message
I'm all thumbs with programs like that. What size box and ports would you recommend? I'd like to make something like a VOTT, maybe even better if that's possible.
(((VOTTica)))
Re: Altec 414 [message #16982 is a reply to message #16981] Wed, 15 September 2004 07:20 Go to previous messageGo to next message
One possibility is a 2 cu ft box with a 1.5 inch length 4 inch diameter duct for an F3 of 60Hz with a bit of a bump at 70 Hz. An Altec A7 box would also do well if you have the space.
Re: Altec 414 [message #16983 is a reply to message #16982] Wed, 15 September 2004 11:10 Go to previous message
Thanks!
Previous Topic: hammer dynamics
Next Topic: Line Array Impressions
Current Time: Fri Nov 13 13:28:27 CST 2026
