Home » Audio » Speaker » Truncated horns
Re: Scoops [message #16932 is a reply to message #16930] Sat, 04 September 2004 13:23 Go to previous messageGo to previous message
The same as any horn: acoustic impedance matching between the driver and the air, and lowering of system resonance. Rear-loading is usually employed with high Fs high SPL low Qts drivers (which most MI drivers are, as are Fostex/Lowther style full-rangers) to get more bass from the driver rearwave.
Most high SPL drivers in sealed or reflex boxes have F3s around 80-100 Hz; hornloading the rear wave can take that down to 40-60 Hz. That's good, but system SPL remains at the the raw direct radiating SPL of the driver, around 95-100dB/watt.
Horn loading the front wave instead allows both lowering of F3 and raising of broadband SPL by 10 to 15dB on average. The downside to front-loaded horns is that to make them long enough to impact the bass they usually are folded, which can limit their high-frequency bandwidth, although that's not the case in my DR horns.
Previous Topic: Tang Band drivers
Next Topic: Line array question using Bandor 50mm driver?
Current Time: Thu Nov 26 09:47:44 CST 2026
