Home » Audio » Speaker » Long throw, Short Throw horns
Long throw, Short Throw horns [message #16841] Wed, 18 August 2004 09:47 Go to next message
DR Carlson is currently offline  DR Carlson
Long throw, Short Throw horns. What's the differnce between the two?
And at what times would you want to use one over the other
Re: Long throw, Short Throw horns [message #16843 is a reply to message #16841] Wed, 18 August 2004 21:09 Go to previous messageGo to next message
Ralph is currently offline  Ralph
I'm no expert but I'll give a shot at it. I think the name implies the difference. Long throw horns have narrow dispersion and are made to throw a wave and be used at a distance. Short throw horns have wider dispersion and integrate close up but don't carry as far. Ralph
Re: Long throw, Short Throw horns [message #16844 is a reply to message #16843] Thu, 19 August 2004 07:23 Go to previous message
That's it, more or less, but in reality the idea of short versus long throw is somewhat specious, as there is no difference in how far a 60 degree horn will 'throw' versus a 90 degree horn if they have the same on axis SPL. What does differ is the width of the coverage zone; by and large one wants a wider beam for a shorter throw so that the audience in close and off-axis can hear it. But this whole concept has been rendered somewhat moot in the pro ranks by line-array technology, which addresses the long-throw aspect via nearfield (-3dB per distance doubling from the source)coverage zones up to 300 feet or so deep, and close-in dispersion with curved (J-Line)arrays.
Previous Topic: Any ESL/planar to work with Aleph 3?
Next Topic: Modify or remanufacture?
Current Time: Wed Nov 04 22:30:02 CST 2026
