Home » Audio » Speaker » What's your favorite driver from 20-200 Hz?
What's your favorite driver from 20-200 Hz? [message #16644] Sat, 03 July 2004 00:18 Go to next message
MCM 55-2421 [message #16645 is a reply to message #16644] Sat, 03 July 2004 07:41 Go to previous messageGo to next message
Fantastic performance for 30 bucks.
Re: MCM 55-2421 - Thanks, Bill, but... [message #16646 is a reply to message #16645] Sat, 03 July 2004 08:54 Go to previous messageGo to next message
even though I understand your answer (favorite because of the bang-to-buck ratio), is there another that you would consider "best", even if the cost-to-value ratio was a lot higher?
Re: MCM 55-2421 - Thanks, Bill, but... [message #16648 is a reply to message #16646] Sun, 04 July 2004 07:07 Go to previous messageGo to next message
The next choice would be the Eminence HL10a, but I'd never use that outside of a pro-sound application. The MCM 55-2421 is what I have in my own livingroom and recording studio subs, and it has nothing to do with price. I always place a premium on what works, and with that being satisfied I then go for value, not the other way around.
Thanks again, Bill [message #16651 is a reply to message #16648] Sun, 04 July 2004 09:41 Go to previous messageGo to next message
So where would I get some details on this driver? [message #16653 is a reply to message #16648] Sun, 04 July 2004 20:17 Go to previous messageGo to next message
I looked at MCM's site, but not spec sheet was found.
Gar.
Specs here [message #16654 is a reply to message #16653] Mon, 05 July 2004 03:44 Go to previous messageGo to next message
http://www.newark.com/product-details/text/mcm/html/cat48/audio_speakers.pdf
Here's what $30 bucks can do. [message #16657 is a reply to message #16651] Mon, 05 July 2004 11:03 Go to previous messageGo to next message
This is the MCM 55-2421 in a 3.3 cu ft 40 Hz folded horn; a larger box could be used to go to a lower Fc if desired.
Box plan? [message #16753 is a reply to message #16657] Tue, 27 July 2004 18:05 Go to previous messageGo to next message
Ian is currently offline  Ian
Do you have a box plan or pictures for this folded horn anywhere? Do you use one or two in your system(s)?
-Ian
Re: Box plan? [message #16754 is a reply to message #16753] Wed, 28 July 2004 13:29 Go to previous messageGo to previous message
Tuba 18 is going to appear in audioXpress magazine this fall, and after it has been published I'll have the projct available on my website. I only use one for my HT and have never come close to its capabilities. It will put out 115dB without even breaking into a sweat.
Previous Topic: Using filters on lowther type drivers
Next Topic: Double Horns-- here is the real deal
Current Time: Tue Nov 03 17:36:56 CST 2026
