Home » Audio » Speaker » Am I wasting space
Am I wasting space [message #16629] Sun, 27 June 2004 08:47 Go to next message
adavis464 is currently offline  adavis464
I'm plainning to use a tapered pipe to about 4'then I'm going to make a u shaped section to go from the tapered section( which is square)to the 22" wide base tapered section and fire it into the floorwith a 20" high cage. My room is 12x13. Or am I just worrying to much and just build the thing .Tim
Re: Am I wasting space [message #16636 is a reply to message #16629] Mon, 28 June 2004 02:30 Go to previous messageGo to next message
when i fold horns,i start at the mouth,choose a maximum depth,folding according to that,for midbass cutoffs normally 2folds are enough
Lately i prefer the S style,for woofer access. my 40hz corner horn,its folded more like the labhorn but expands in 1 dimension not 2.
for my jbl horn 3folds are more optimal,no space wasted
see my site.
http://www.geocities.com/basshornguy/good2.PNG
labhorn.
Re: Am I wasting space [message #16638 is a reply to message #16629] Mon, 28 June 2004 06:01 Go to previous messageGo to next message
Martin is currently offline  Martin
Tim,
I am not sure if I understand your geometry. Are you trying to make a horn, a TQWT, or a TL? It sounds like a TQWT with the small end at the start of the taper, then 4 feet of straight line tapered, a fold into something else, then I am lost. If you could expand you description a little maybe I would have some constructive comments.
I am also using a smaller room (14 feet x 14 feet w/ 8 foot ceiling) for my stereo system so I have a bit of experience. I have several medium to big floor standing speakers residing in this space with pretty good results.
Martin
Re: Am I wasting space [message #16640 is a reply to message #16638] Tue, 29 June 2004 10:18 Go to previous messageGo to next message
Mcbean 1/4 space design mouth 529sq cm 120 cm long mouth of this section is 2000 sq cm (THE FIRST SECTION IS SQUARE)to a small U shaped section SQUARE1 end RECTRANGULAR OUT END 22" wide at about 3000 sq cm section 2 from 3000 to 10000 sq cm on 20" cage off the floor jbl 2240 driver
Re: Am I wasting space [message #16641 is a reply to message #16640] Tue, 29 June 2004 10:21 Go to previous message
Sorry, nothing to offer. You are beyond my experience base.
Good luck,
Martin
Previous Topic: starting construction on bass horn ?
Next Topic: Speaker Experiments
Current Time: Sat Oct 19 15:24:17 CDT 2024
