Home » Audio » Speaker » How do you calculate the optimal back chamber size for a frontloaded bass horn?
Thanks a lot and a few more questions! [message #16579 is a reply to message #16578] Thu, 03 June 2004 10:36 Go to previous messageGo to previous message
Peter Krojgaard is currently offline  Peter Krojgaard
Hi Bill,
Thanks a lot for your answer. You just know it all!
McBeans program actually display impedance based on the T/S parameters of the driver(s)and the actual horn, of course, so I hope I can use these program facilities as a rule of thump.
However, the program displays both Acoustical and Electrical impedance.
Question 1:
Please correct me if I am wrong, but is it the Electrical impedance you refer to in your reply?
If it is the Electrical impedance you refer to, then I would like to know how critical 'reactance annulling' is soundwise (Unfortunately, I have already ordered the cabinets that might be too small, so it may be an expensive lesson - at least to me!).
The cabinets ordered have a back chamber volume of 120 liters, which gives an Electrical impedance peak at about 32 Hz, while the Fc = 29.11 Hz. According to your answer, this indicates that the cabinet is too small!!
With your added knowledge I have now been changing the numbers in the program, and these simulations indicate that I have to increase the back chamber volume to 160 liter in order to push the electrical impedance peak from 32 Hz down to 29 Hz.
Question 2:
Would such a change (pushing the impedance peak from 32 Hz to 29 Hz )make a large difference soundwise?
I thank you a lot in anticipation and look forward to hear your answer!
Regards
Peter Krojgaard
Previous Topic: New Fullrange Driver Forum website is running
Next Topic: Looking for T/S specs for EV LS-8
Current Time: Thu Nov 05 18:21:38 CST 2026
