Home » Audio » Speaker » Hey Graeme!
Re: Hey Graeme! [message #16571 is a reply to message #16570] Tue, 01 June 2004 19:57 Go to previous messageGo to previous message
GraemeG is currently offline  GraemeG
That's basically it. The 2445s have a measured hump around 2k that gets really hard on the ears when pushed hard. I am not a fan of 2" drivers and don't really like crossover points in sensitive vocal areas, so I much prefer the sound of 1" drivers crossed over much higher. The 2x8" box is much more pleasant to listen to at high volumes. I am really aiming at higher crossover points, and hopefully experimenting to be started shortly will achieve that.
FWIW most of the problems with extending the top end of the 12s was due to path cancellations due to the small throat area. Using a larger throat (as was done in the 8") probably could have increased the top end range at the expense of overall efficiency. As the boxes were already existing, I concluded that going for smaller drivers was probably easier than trying to redesign and rebuild the 12s.
Cheers
Graeme
Previous Topic: ALE, Goto, Oris
Next Topic: Full Range Driver website on the fritz
Current Time: Thu Nov 05 21:58:54 CST 2026
