Home » Audio » Speaker » Horn Cab for the Lab 12
Re: Horn Cab for the Lab 12 [message #16503 is a reply to message #16502] Mon, 17 May 2004 04:30 Go to previous messageGo to next message
just an example
i dont have that CAD file anymore. ITs a simple matter of redoing it,to your exact specifications. Email me with Exactly what you need,and i can CAD you up a similar thing. Notice also that the lab12 is a physicaly HUGE woofer,huge magnet,that woofer in the diagram was just a test.
Cheers!
phase plugs [message #16508 is a reply to message #16482] Mon, 17 May 2004 17:41 Go to previous messageGo to next message
Hi Grame
Will the phase plugs look anything like these?
Looks like a lot of precision is needed, looks hard! Can you post results here of what happens when you get around to building some phase plugs.
By the way those scans above are from AES Preprint 1384, application of bob smiths phasing plug.
Adrian
Re: phase plugs [message #16509 is a reply to message #16508] Mon, 17 May 2004 17:43 Go to previous messageGo to next message
Sorry about misspelling your name. Man, I dunno how I did that, I even checked to see if I spelt it right because I spelt it with a 'h' before in the past so I wanted to make sure I got it this time. My eyes must be playing tricks on me cuz I swear I had it spelt right when I typed it out :p
Re: phase plugs [message #16512 is a reply to message #16508] Tue, 18 May 2004 05:42 Go to previous messageGo to next message
GraemeG is currently offline  GraemeG
Hi Adran.... (small dig at spelling!!!! - but used to spelling mistakes on these forums)
Yeah, a bit like figure 5, but with only two rings instead of four. This will be reasonably small, so a bit of precision and patience will be required. Once I get a design I am happy with, I will investigate getting them moulded in fibreglass.
BTW recognised the scan - I have that article.
Cheers
Graeme
Re: phase plugs [message #16513 is a reply to message #16512] Tue, 18 May 2004 17:04 Go to previous messageGo to next message
Hi Graeme
hahaha.
Will you make the phase plugs yourself? Perhaps CNC/CAM would make things a lot easier.
Adrian
Re: phase plugs [message #16514 is a reply to message #16513] Wed, 19 May 2004 00:22 Go to previous message
I will make the initial ones from layered MDF and lathe to shape - it's a lot easier than you would think.
Cheers
Graeme
Previous Topic: Speaker Question
Next Topic: Audiophile Sub project
Current Time: Fri Nov 13 08:48:55 CST 2026
