Re: sub horn for 2240 [message #16473 is a reply to message #16471] |
Fri, 14 May 2004 15:16 |
Bill Wassilak
Messages: 402 Registered: May 2009
Illuminati (1st Degree) |
Down load a copy of this program and take both measurements and put them into the formulas, this will give you a read out of what to expect. HTH Bill W.
There is some science, but still horns are mostly art. [message #16477 is a reply to message #16476] |
Sat, 15 May 2004 13:49 |
Bill Fitzmaurice
Messages: 335 Registered: May 2009
Grand Master |
Download the McBean program as was suggested and you'll find that you can build virtual horns with many different parameters and get many different results. What horn you should end up building is determined by your particular needs in terms of available space, required bandwidth, desired SPL and so on. Experiment. You at least have the advantage of a computer program; I built probably 50 horns with no way of knowing how they'd work until I built them. There are many ways to build a horn, with so many permutations of both the driver specs and horn dimension specs possible that I'm sure the combinations add up to the millions. If what you desire is a short quick answer on the 'correct' way to build a horn I'm afraid that there isn't one. I designed my first horn in 1969, and I still have not achieved the Holy Grail of the 'Perfect Horn'. Give me another 35 years and I might get close. If you're serious about learning about horns required reading is Olsen's book on Acoustical Engineering, available through Old Colony Sound at www.audioxpress.com. As for both Leach and Keele, according to their formulas all of the horns I've built over the last ten years, including the pictured DR250a, could not possibly work. They do work, which is why I say use the math as a guide, but not as a crutch.
mcbeans prog [message #16487 is a reply to message #16478] |
Sun, 16 May 2004 05:35 |
Mike.e
Messages: 471 Registered: May 2009
Use the hypex tool first to attain a response that you want.Then minimise the parameters eg :: make throat area 'correct' and realistic :: make mouth area a realistic size,eg not 20,000cm^2 unless you can fit that.play til its flat response again with Vrc and Vtc :-) Cheers!
OOPs [message #16493 is a reply to message #16492] |
Sun, 16 May 2004 07:59 |
Mike.e
yes the HF isnt usable with this program,but this is pretty lowstuff so it didnt come to mind :-) Cheers
Re: OOPs [message #16495 is a reply to message #16493] |
Sun, 16 May 2004 21:35 |
Messages: 18707 Registered: January 2001
God, Mike, how do you get those great sunset photos? Oklahoma has some really beautiful sunsets and I have a pretty nice camera but never seem to be able to capture them like you have. Maybe the trick is to enhance the contrast? Whatever the case, that's a beautiful sunset.
