Home » Audio » Speaker » LC tuning instead of ports
Re: LC tuning instead of ports [message #16431 is a reply to message #16430] Thu, 06 May 2004 16:44 Go to previous messageGo to previous message
I'm familiar with the Bag End subs that are run under-resonance. The idea of using a corresponding filter to match slope is pretty cool.
About vented systems, woofer excursion rises below fb, and it should be limited to use above fl in high-output situations. Use of EQ to increase output below fl wouldn't be cool in a vented system if output was high, and really not that beneficial even at moderate outputs.
I suggested the EQ scenario for sealed systems, and my point was that if a sealed system is equalized to mimick the frequency response of a vented system, then all the other characteristics like damping and group delay will match too.
Previous Topic: Lowther cabinets
Next Topic: Backhorns
Current Time: Tue Sep 29 10:56:10 CDT 2026
